HBS 2" Level...35's?
DeputyDipShizz
Pennsylvania
Will they fit with stock 20's and what fer size am I looking for...Damn metrics screw me all up
=DROID=
txbass06
NE Texas
5.9 Magnum
Are you wanting a 35x12.5 tire? If so, the metric size is 315/60R20.
DeputyDipShizz
DeputyDipShizz
Pennsylvania
That's what I'm lookin for...sobwill they fit...and do I need wheel spacers?
=DROID=
quietpeen
2021 TRX
Hellcat
I though 305 was the equivalent to 12.5 inch wide.
Like 305/55/20 = 33x12.5x20
also I just noticed that you have an 06 and want to use the stock 20's. With any tire wider than 285, you most likely will need a 1/4" spacer. I say most likely because not all truck are made exactly the same and there have been some 06-08 rams that have fit 35x12.5x20 on the stock 20's with no rubbing, but there have been many that have had rubbing on the upper control arm.
ramhunter9
P-Star Jeep Wrangler
2" level and anything 12.5 and over will require you to trim the rear section of fender .
Marx
Southeastern Ontario Canada
Hemi 5.7L, 345 ci MDS
~ = approximately
1. 315/60R20 = ~35x12.40R20
2. 35x12.50R20 = 318/~60R20
3. 305/55R20 = 33x12R20
1. Section Width: 12.40 in 315 mm
2. Section Width: 12.51 in 318 mm
3. Section Width: 12.00 in 305 mm
1. Overall Diameter: 34.88 in 885.95 mm
2. Overall Diameter: 35.02 in 889.50 mm
3. Overall Diameter: 33.20 in 843.28 mm
1. Sidewall Height: 7.44 in 188.97 mm
2. Sidewall Height: 7.51 in 190.75 mm
3. Sidewall Height: 6.60 in 167.64 mm
1. Radius: 17.44 in 442.97 mm
2. Radius: 17.51 in 444.75 mm
3. Radius: 16.60 in 421.64 mm
1. Circumference: 109.5 in 2781.3 mm
2. Circumference: 110.0 in 2794 mm
3. Circumference: 104.3 in 2649.2 mm
and i think the 06+ require a wheel spacer
great tire calulator here http://www.1010tires.com/tiresizecalculator.asp
4.7Ram5.7Rango
Lynchburg, VA
4.7 Flex
Im sure you already thought about all this.... but do you plan on doing much/any wheeling? Not gonna have a lotta room for articulation with 2in level and 35s, hell, probably none. I know there isn't really a whole lotta room with what I have, which are just 33's....
p.s. Im not exactly sure about the b/s and all that on the 20's, but I'm rubbing on full lock with an approx. 11.5in wide tire.... better plan on spacers ;)
infernoredram
South Texas
5.9 Cummins
Idk if the half inch makes a lot of difference, but I have 35's on a 2.5 inch level and have no rubbing at all with after market wheels. I was told it was going to rub with the stock 20's so I just got a whole new set up. When it comes to wheeling, those guys are right, you aren't going to have much flex room..especially if your turning.
BTW if you need any spacers I have some if you're interested.
DeputyDipShizz
DeputyDipShizz
Pennsylvania
The occasional light trail but nothing involving tons of flex...I'm familiar with trimming inner fenders as I had 285 75's on my Dakota with a slight That crank...Love stuffin those wells...Unfortunately well priced aggressive tread 35's are hard to find for 20's :-(
=DROID=
matt99
Shreveport, LA
I have the federal couragia m/ts on stock 20s. I paid $1300 for everything but people have found them for about 75% of that online. I have 1.5in spacers
stevenmicheal
