jlb
So I have a 2011 1500 that I want to make a little beefier. I tow a lot, and haul a lot, enough to justify a 2500, but that is another story.
I want to upgrade the front springs on my truck to something with maybe a 25% or so higher spring rate. I am hoping this will give me about an inch of lift, maybe 1.5, but also significantly reduce dive/squat in cornering, and braking, especially under load.
I was wondering if, a) anyone has done something like this, and has some springs to recommend, and b) for those who have done lift kits, etc, what kind of changes has the lift made to camber/toe? Have you all gone, and gotten professional alignments done after installing the systems or have any of you done the full job yourself? Of course this is based on the assumption that our trucks have a non-infinite instant center for the front a-arms, but I truly have no idea.
Also, to make her match on all four corners I am going to add a set of air bags to the back, and an on-board compressor. Any recommendations on which set of bags is best in terms of overall cost, and quality?
Thanks for all your input.
