Headlighs
Soonergrand
I had the passenger headlight stop working, no high beams and no low beams. I don't know what caused this. Then it comes back on, anyone have any ideas?
BassDaggett
Twin Lake, MI
EcoDiesel
Stock or aftermarket headlights?
Are these stock (halogen) or aftermarket (LED, HID, replacement) lights? May also want to let the forum know if you have Quad or Projector lights. I more than likely won't have a solution, but there a lot of helpful folks on here.
S
Soonergrand
I replaced the low beams with HID, one side still worked. They are stock assemblies and no change in wiring harness.
NJ4X4
South Jersey
I've heard it's a problem with some Rams around that year. A friend of mine has a 2010 and has had that intermittent problem for awhile now. After doing some research online, he found out it's the connector at the main plug wire behind the light. He tried slightly bending the tabs inside the connector to make a better connection. That worked for maybe 6 months or so and the problem returned. He finally did what others suggested... He cut out the connector plug and used electrical connectors to re-connect each of the 3 wires. No problems since doing that. Hope this helps!
adurm
FL
2015 RCSB
I'd suspect corrosion in the ram to headlight plug.
Wahrsuul
Central S.C.
Yup, sounds like the connector plugs. My 09 had the same issue - the passenger side headlight kept going out. I pulled both headlights out, cleaned the connectors, gave the male side a slight twist, then liberally doused with dielectric grease and put it all back together. No problems since.
WilliamS
Tampa FL
could be the connector, or could be the truck not recognizing there are lights attached. Some need a resistor to trick the truck into the resistance needed to fire them up.
