Headlight conversation question
rruby0528
I bought the wrong headlight housing and need to know if there is a legit way too go from quad headlights to dual. Is there an adapter to go from the stock bulb to a h13? Thanks in advance.
BlownGP
Houston/Baton Rouge
The plugs on the back of the light housing on duals and quads are both the same
Yup, doesn't matter what lights you get. They are same.
Same goes for the aftermarket lights you see on ebay. They all will work on any RAM unless your's came with projectors.
R
rruby0528
Thank you everyone. Do just remove the harness for quads and plug the h11 bulb right into the larger plug?
BlownGP
Houston/Baton Rouge
The headlights bulbs are connected within the headlights. You are just pluging in the main harness wire that comes off the headlight to the one that's on the truck.
Once you take off the headlights. You will understand. Now if you had HIDs, that can get a little tricky if you've never done it before.
stevenmicheal
