Headlight harness
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
So I got my LMC headlight harness tonight and I was looking at everything. Where is the existing/ factory headlight harness at? I need it to plug into the LMC one and can't find the connector unless I'm totally blind...
rowdyram
magnum 5.9
You need to remove your driver side light to see it. The pass side can be seen from under the hood looking inside the inner fender or you can pull that light too.
1SilverBullet2
1SilverBullet2
North Dakota
Ok my DS headlight is removed. i'm gunna ask the dumb question, but is the connector that is actually connected to the headlight the one I'm looking for or is it tucked inside in the fender behind my headlight?
