Headlight Problems
Cz17
2009 Ram Sport
Found out I had a low beam light out as well as high beam light on my passenger side while the marker light and signal light still worked. Pulled the bulbs and they were fine, they worked in the other side. Reinstalled the bulbs on the passenger side and they wont work. Figured my next step would be to check the fuse. I cant seem to find a fuse for the headlights, is there such thing? Any other suggestions to fix this problem?
Pickles
Northern California
I'm not certain at all, but would assume the fuse would be for the headlights total, not per side.
Try checking the wiring harness as well. I've seen lots of problems in these lately in many different vehicles.
sbarron
Wasilla, Alaska
Start by checking power at the plug and work back from there.
