Jgibson4106
http://www.moes-performance.com/mobile/Product.aspx?ProductCode=I3-PCM-2019EXCHANGE
Just ordered mine last night.
Not something I care aboutYou do know that if you take your truck in and if they do an update that they will lock that computer and you won't be able to do and adjustments unless you Diablo to unlock it again.
Wonder if it’s possible to just buy the unlocked PCM with the tuner, take out the stock PCM and set it aside (would cost more without the PCM tradein). Then if you ever need to go to the dealer for anything you swap out the unlocked PCM for the stock one. Hmmm, will that work?You do know that if you take your truck in and if they do an update that they will lock that computer and you won't be able to do and adjustments unless you Diablo to unlock it again.
If only one could increase mpg and gain range with one of these tuners. More horsepower and faster shifting only means shorter life for the transmission and torque converter.
Look like you can purchase the PCM outright.
http://www.moes-performance.com/mobile/Product.aspx?ProductCode=I3-2019
I've had this on my truck for about 2 weeks. I was having issues with Pulsar, and swapped it out for the i3. Been great so far, much better than the Pulsar.
How’s it compare to the Pulsar performance mode?
With the Diablo Tune 93 Oct, it feels about the same as the performance mode in the Pulsar. I cant say whether one has more power than the other, they both feel pretty equal under WOT.
The main difference I notice is drivability. The Diablosport feels like it's a factory tune. Throttle response is good but not too touch. The pulsar was way too sensitive in performance mode. You were constantly reminded that your had a piggyback tuner, with the diablosport it feels natural.
I was also having some issue with the pulsar, same as many people have had. No issues at all with the diablosport tuner
