Heads
mairj40
Iowa
2003 and 2009
I'm rebuilding a 2005 Hemi for my truck. The donor engine had dropped a valve seat. I know these engines are prone to this if they are ran hit. What years had this issue? I was going to switch it to Eagle heads to get around it and add some power. But I'm wondering if there are other years that they had remedied the valve seat issue.
HemiLonestar
Navy Badge Coast Guard
MD
Any pro rebuilt head should have this problem solved. Pretty much most of the run from 03 to 06-07 it would happen randomly, but you have to get them seriously hot. You could put eagle heads in an 03, but not likely you'd be able to take much advantage of them since the 2003 PCM is absolute **** for tuning (plus you didn't mention a cam; absolutely no point adding eagle heads to such a small cam).
mairj40
mairj40
Iowa
2003 and 2009
Thanks for the info. I am switching to a 2005 PCM. I'll be adding a cam and getting a custom tune.
Hemi dude
