Help Support Ram Forum by donating:
Heat 2nd gen
Discussion in 'Interior' started by cxf, Dec 2, 2019.
  1. cxf
    cxf Junior Member
    12
    Nov 2, 2017
    Ram Year:
    1999
    Engine:
    5.9
    Hi I’m back again. I just went through replacing the crank sensor and cam sensor as well as new cap and rotor. Truck is running great but, always a but, I now have no heat. Is the blend door vacuum operated and could I have knocked a vac line loose when working blindly on the cap/ rotor or cam sensor? I am at work and do not have my dodge manual with me. Thanks in advance.
  2. thestuntboy
    thestuntboy Member Supporting Member Military
    54
    80
    Nov 3, 2017
    CT
    Ram Year:
    1999 2500/2001 2500/2018 3500
    Engine:
    8.0/5.9 gas/6.4
    If you had heat before then more than likely a vacuum came loose. Look at the back of the engine on the right side for a loose hose. You might hear some whistling at the connection port.
    Mop likes this.
  3. Nealuss
    Nealuss Member
    43
    Mar 8, 2016
    Ram Year:
    1994
    Engine:
    5.2L 318
    Yes you absolutely could have. There is a vacuum tee by the firewall on the passenger side of the intake with a check valve in it. When disconnected it should default to defrost only.
Share This Page
