Heated Steering Wheel Conversion
Wayne E
Winnipeg, Manitoba, Canada
Hey guys/gals, I have a 2018 Express 5.7 4x4 1500, and wondering if I can easily put in a heated steering wheel? Living on the Canadian Prairies gets very cold. We've already had wet sloppy snow last 2 days.
Still low 20's over here in Alberta,lol
emjohn4
I have a 2012. Added the heated steering wheel.
Needed the HSM, Clockspring, switches, and the wheel (of course!). And programming via Alphaobd.
A later 4th gen probally only needs the clockspring and wheel; and be sure if you already have heated seats that your HSM has the plug and wiring for the heated steering wheel.
It's not a cheap upgrade....wheel was about $450 from Rockauto, and the clockspring was about $250. I already had the HSM (~$150, IIRC) due to the heated seat install I did.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Did you have to get a harness or have any pictures where you would plug in the HSM etc. I have an SLT k want to convert but not sure if plugs/wiring I will need are there or not.
emjohn4
I don't have any pics (personally), but I can point you in the right direction.
The link here (https://www.ebay.com/itm/314216622353) is a clockspring equipped for a HSM. The black harness with the white plug is the heated steering wheel connector that plugs into the steering wheel harness (in the steering wheel itself).
On the backside (see pics below), your truck, if wired for it, will have a blue connector that plugs into the dummy slot shown in the first pic (circled in blue). Note on the second pic (circled in red) - it is the same location, but shows where the connector goes to if it isn't just in the dummy location (pic 1).
Hope this helps.
On the HSM part, I had to adapt the seat wiring harness to the truck harness. All the wiring was there on my truck on the 'truck side' but not in the seat. Pins 12 & 20 are the heated steering wheel feed from the HSM to the truck harness.
  • 20-way connector.pdf
Keith1316
Fort Worth, Texas
6.7 Diesel
Hi! I have a 2016 Tradesman that I added a heated steering wheel to. I bought a new clockspring and installed it. I have upgraded my stereo to the 8.4 UAQ, and my instrument cluster to the 7” display. I have turned on heated wheel with AlfaOBD. I also installed the switch panel for the heated wheel. My problem is I don’t know where/how to install the HSM??? Can you help me please? I have been searching for a long time but can’t find the info I need. My name is Keith! I would appreciate your help please.
Canadian-Hemi
Ontario, Canada
2016 Shorty (RCSB)
5.7 L
Hey Keith did you figure it out? I'm in the exact same situation. My Heated wheel shows up on the 8.4 display but turns off after about 15 seconds.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
The module is under driver seat.
