Raife
- Aug 18, 2022
- 69
- 35
- Location
- Texas
- 2020
- 6.7 I6 Cummins HO Turbo Diesel
Evening everyone. I have done a search and read some posts regarding a similar issue, but I haven't found if anyone solved it...
I bought a used 2020 3500, CC, LB, HO Turbo Diesel 12" UConnect about 5 months ago (i.e. no warranty). I noticed a couple months ago the heated steering wheel would sometimes work fine and other times it would come on for about 20 seconds and then turn off. I have been trying to determine a consistent pattern or trigger since to no avail. Sometimes it works with the remote start and stays on (all instances tried were high 30s); sometimes it works when I manually select it under the controls...and most times it doesn't. The heated seats work fine all the time.
Now that it is a bit chillier here in central Texas, I was hoping someone had solved it...
Thank you.
(P.S. I know cold is relative as I grew up in New England, spent 8 years in central NY, and 11 years in CO).
Thank you.
