Well if that works for you, like you say, every advantage helps.
There is one potential issue to be aware of worth mentioning ...just something to be aware of. This is something new car engineers probably struggle with. Putting a valve to the heater core is somewhat controversial. It's been reported on some classic car forums I also go on, and even the Jeep XJ forum, that installing a valve at the heater core can actually kill a heater core. It comes down to the valve's placement, is it a byass valve ...or is it even worth using one at all?
What can happen with a valve ( especially if installed on the inlet side of the heater core line) is, crud and sediment can build up in front of the valve over the months of non-use. It can be rust sediment, mineral deposits, pieces of gasket material, hose or whatever, which became dislodged. Whatever crud is floating around a cooling system -- the older the vehicle the more there'll probably be. Guys have showed the crud on like the XJ forums. Then, when an owner turns on the valve, say in the fall, they my 'slug' any built-up crud which happened to collect and get trapped in the no-flow area of the valve or hoses. That crud can go right into the heater core. That can lead to plug-ups which may or may not be able to be dislodged. The passages inside the heater core are quite small. If the valve is on the output side it's may not be as bad because it has time to go through the system and hopefully get broken up before it goes through the h/c. But even that is controversial b/c guys have indicated sediment can still build up to a degree in the inlet side (of the coolant line) because the coolant is basically not flowing and some debris can collect in the hose. I dunno. It comes up on the XJ forums because heater core failure has been rampant on those vehicles and they came stock with shut-off valves. At least the early ones did. And so did GM cars of the 70's-80's.
So there's controversy on weather the risk of having to remove the dash to replace the heater core makes it even worth using a valve at all, or if so, where to put it, or use a valve with a built-in bypass (preferred) ....or remove the hoses and them out in the fall prior to using the heat. Esp if there is a good-working heater damper which closes off the heat during normal use.
Not trying to scare ya, but pointing out something to be aware of, so you don't inadvertently run into a situation of unintended consequences which lead to more expensive downstream issues. Removing a dash to replace a heater core (if that's what it takes on a Ram, is a LOT of work). I've done it on other vehicles. If the valve is on the downstream (discharge) side of the coil's coolant flow, that would probably be a safer spot for it. A bypass valve would be even better.
Here's what a bypass valve looks like. There are different styles (this is just one). There are also solenoid actuated bypass valves too (do a search).
