Heater
muzupan
Rocky Mount NC
2019 Ram1500 Crew Cab
This may be a dumb question: On my Ram 2015 1500 I do not see a button to direct the heat to the floor. Every vehicle I have ever owned had a button to direct air to the floor. I dont care for the heat blowing directly out of the vent. There is a air duct pointed to the floor under the dash.Can this be done in thte Ram 1500? Any ideas?
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Did you read your owners manual? Depending on your controls, either you have a knob selection or a touch screen button that shows a seated man with an arrow pointing down on his legs. This is floor mode but some will vent on the side window defrost outlet vents.
xrsman
Ontario
3.0 Ecodiesel
Check out your manual. If you have a touch screen it'll be in the climate section
Sent from my SM-G920W8 using Tapatalk
M
muzupan
Rocky Mount NC
Thanks everyone, that is where it was at in the climate section of the control panel. I have been there before and never noticed it.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
At least you asked instead of living with it...
