Hellwig Sway Bar
TXCOMT
I installed greasable links from Core4x4 on my truck, they’ll make them to whatever length you want.
https://www.core4x4.com/product/dodge-ram-1014-present-rear-end-links/
Yeah, that's the one thing the Hellwig links don't have...good ol' zerks! Otherwise, they're no doubt as stout as other aftermarket adjustable models, but they made noise on my RCSB and the Reb I drive now, so back to the stockers for me. That swap did the trick...no noise now, but every time I see those Hellwigs, I shrug. Heck, maybe I just didn't install them correctly!
Maybe I'll put some zerks on 'em, grease the snot out of 'em and reinstall.
TXCOMT
KnurledNut
SemperFi
Sonova Beach
Part number for the Moog links, K'Nut? While I have the nice adjustable models from Hellwig, my Hellwig bar always made a clunking noise with 'em...I swapped back to the stock links you've pictured on the left and no more noise. Maybe the Moogs will be quiet!
TXCOMT
Moog K750396. Got mine from Amazon for $25 each.
TXCOMT
Thanks! I may pull the trigger on those if I can't get my Hellwigs sorted...or I could sell 'em and keep the stockers mounted to the Hellwig sway. I've had no issues so far!
TXCOMT
TonyMM
2016 RAM 1500 CC 6"4 4X4
I have a 2016 crew cab with the factory air suspension and I am quite pleased with it.
I don't tow or haul anything.
Would the Hellwig bar still improve the handling?
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Is the Hellwig bar good for stock height trucks as well as lifted?
gdawg55
gdawg55
GA
Yes. I think they have different part numbers though for stock trucks vs lifted.
JB1
Houston, Texas
Do you know of anyone using these on a 2019? On the website they say to present but only list up to 2018.
I’ve read about some 5th gens using the same Hellwig rear sway bar part number as the 4th gens so I can only assume the core4x4 endlinks would work as well. The endlinks use the same bolt size for top/bottom.
CincyZach
Cincinnati
Yeah I've been reading the same thing and that's what I'm thinking about the endlinks too. I've seen it confirmed that the Hellwig sway bar fits, so I ordered that. Think I will call them about the endlinks and unless they say they know they won't fit I will probably try them and see. Thanks for your input!
Reactions: JB1
CincyZach
Cincinnati
I called them and they confirmed they will fit, so I ordered them. We shall see soon.
Reactions: JB1
78Staff
US Navy Veteran
NE Florida
I've been happy with mine - minor snafu I bought the "kit" with adj. sway bar links and the bar hardware kit was wrong, it was for a larger size. So they send me replacement clamps but not replacement bolts, so I sill have the stock bolts mounting the bar, not the snazzy Hellwig Allen head bolts. Not a bid deal but every time I see a pic of someone else's I think man those bolts look so much better lol.
Reactions: JB1
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
I didn’t have an 8mm Hex drive impact socket so I reused the stock ones and painted them!
Ain’t nobody got time for Allen wrenches.
DILLIGAF
Canadian Forces
Canada
The included Allen bolts rusted out after 1 winter. so did the adjustable endlinks. They dont even salt our roads in Alberta FFS... Junk !
