ldsman
Could use a bit of help here. I’m trying to replace the blasted turn signal on the driver’s side. I pulled the passenger side just fine. Removed the four screws same as passenger and it just won’t move. The manual says to remove the fuse/relay mounting bolts as well, which I’ve done. Still won’t come out. Is there another screw or bolt?
Nvmd. Pulling really hard freed it.
