BumpInTheNightEdi
I got a new batt and it still was no different. Do you think i could have fried a wire?
https://ln.sync.com/dl/8279e10e0/wpp99a75-w75qtr3h-hzeff67w-c4tdwxxn
Plug a scan tool in and pull the codes and see what modules are down for starters. I'm going to upload the starting circuit, starting troubleshooting tree and theory of operation shortly. You should be able to see in a short time where the problem lies. Three files in that link they are all pdf's. In order to view them you may have to zoom in on the schematics with Cntl and Plus key.
By the look of the schematic you may have caused the bus to go down on the body module.
The LEDs in the IGNM and Start/Stop Button provide visual indication of the ignition system and button use to aid the driver. The Logic for LED control is implemented in the RF HUB. The Start/Stop Button contain four LEDs: OFF Indication ACC Indication (Accessory) ON Indication (On or Run) Ignition Switch Indicator (button backlight) The LEDs indicate the vehicle ignition position and are driven by the CAN bus signals related to the ignition position. The Center LED (Ignition Switch Indicator) will blink if there is a related concern. The RF HUB will log a DTC indicating an incorrect Ignition status value is present; in this state the ignition status is unknown. This will continue until the correct signal is received by the RF Hub. EVIC Operation The Keyless Go feature requires the vehicle to be equipped with an EVIC display for prompts and status information. The display messages are: Service Keyless System FOB Not Detected FOB Left Vehicle Not in Park Push Brake Pedal and Push Button to Start Push Clutch Pedal and Push Button to Start Vehicle not in Park Warning.
No leds no bus I'd say.
Good information on your link, thanks
Hi Dave.... interesting stuff. How may I ask did you come about those documents? Thanx... Jeff
