help engine surging at idle
93ramguy
nashua nh
help guys i own a 1993 d150 with a slight issue when i sit in park with the engine running the engine idles higher and lower again i was thinking that it might be the idle air control valve . But i have not had the chance to look in to it. Any ideas ? gonna try to clean the trottle body and idle air control valve in the morning. truck is a 3.9 with new plugs , new cap and rotor , i am kinda stumped at this point. thanks in advance .
jakefrancis127
most likely the idle control. i had a 93 ramcharger that used to do the same. cleaned to TB, that helped for a while. eventually had to change the valve
93ramguy
93ramguy
nashua nh
just to update you guys it was the idle air control valve swapped it out and no more issues thanks for the help!!!
