Help get Silver running again!!
S
Silverbullet08
Persona Non Grata
Did you? Was I driving like my normal idiot self? Oh wait it was raining I think the last day I drove the truck, so you must have seen the calm Sam? :D
yea it was raining. it was right by lincoln square. u were at the light and i was going the other way
I didn't mean to ruffle feathers, it's not a bad cam. We've put more than one Hemi truck on the track though and they weren't running this cam. A lot of people do like the sidewinder though. I guess I should have said that if I were going to do a cam swap I'd go a little more aggressive.
My point is that it's not very aggressive and doesn't require a custom tune. Although not recommended, I've seen this cam run fine on a stock PCM tune was the point I was trying to bring across.
Is a boy I work with at the dealership runs a Comp 260 in his truck, very similar cam with only a superchips and I think it's even the older one that you can't update on the internet and he runs fine.
Anyway, Silverbullet08, if you come to a stop and brake with your left foot and kept giving it a little gas with your right foot, no problems? How high do you have to keep idle before it stalls? Will it still stall if your A/C is on?
there are lots of guys running the sidewinder on custom tuning. some having the same issues as mine. yes the plan was for it to work with my superchips which is why i chose the sidewinder. but that doesnt look like it will be the case does it?
anyways yes ive been two footing for the last couple weeks. keeping the rpms around 600-800. ac does nothing for it. two footing also give the pcm fits...
What is that supposed to mean? Lol
the needle is going crazy. like back and forth really fast....
S
Silverbullet08
Persona Non Grata
boo, here are the graphs from another member who has a sidewinder and runs 12.3 in the 1/4...
Impressive graphs. That last set shows huge gains with psc tune. Wonder how much more a custom delivers.
shadow11
Banned
Houston TX
Yep my tranny gauge did the same thing on friday and it was a bad ground.
S
Silverbullet08
Persona Non Grata
yea i remember reading on lx that they got really good numbers with a custom tune
shadow, thats good ill check them when i get home. its prob the one around the tranny...
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I can't wait to hear the results. It's time for you to catch a break.
S
Silverbullet08
Persona Non Grata
i sure hope i can get all this stuff fixed... im ready to enjoy this it and not have to worry about it all the time...
truckin151
2013 sport
It will, bump the idle up to about 8-850 and the tire size and see what it does. Then worry about the other things the dsp can do
Oefootball_70
OLATHE
Tonight is the night then? Hoping for you that everything goes smooth with the trade and ability to custom tune the truck.
truckin151
2013 sport
tire size?
Yeas tire size, that would be the only other adjustment I would make on your first startup with the idle raised. You gotta be able to drive the speed limit...errr... close to the speed limit right? I think it auto defaults to 31.5" tall tire unless you tell it otherwise, at least that is what mine tells me whenever I readjust or reload the tune.
ALSO, be sure you download the DSDL and the Data viewer too. And see if the DSP the guy is trading you comes with the usb cable and power adapter (otherwise you need to go pick those up) and make sure it is on the latest revision, 9r09 CROM. If it is on 9r06 you wont have trans control, same with the 9r07. The 9r08 fixed it for the most part and the 9r09 is a little better yet tune wise.
You may also need to load the DCX Calibration update as well but it will prompt you for that so just be sure that you have the DSDL and the cables ready to go.
And one last thing, since yours is an 05', before you plug the tuner in to the OBDII port, turn the key to the on position (not starting it) with mine and a bunch of other 05's if you do not do this step first it wont read the TCM. On the initial tune it will normally see it but if you go in to make any revisions or adjust anything and you dont do that it will sometimes not read the TCM. So to be safe, be sure the key is in the on possition before anything gets plugged in.
truckin151
2013 sport
And after you load it, go to the tools menu and show calibration ID and it will give you a pcm code and a tcm code, if it doesn't you need to rest the truck to stock and try it again. Also check this before you return the truck to stock for any reason or it will keep diablos tune loaded as your new "stock" tcm file (I did that once)
S
Silverbullet08
Persona Non Grata
ok thanks. the guy im trading with has the 4.7 idk if that makes a different but it does come with the computer interface kit. i just asked him about the crom so we will see...
stevenmicheal
