Help help!!! 6x9 Upgrade for 2017 Ram 1500 with Alpine
CanuckRam1313
Ontario Canada
Yoooo, this looks great! What box is that???
The shop indicated it was a custom made box for the sub and fitment of the Ram under-seat storage area.
Although, there are several single 10" sub boxes I found on the googler available for the rear under-seat space. Just type in your year, and rear under-seat single 10" sub box for (crew cab, or quad-cab).
Crutchfield on-line also has these single 10" sub boxes, too.
texas law dog
3.6l v6
Can someone please tell me what's the best plug and play options for replacement 6x9 speakers in a 2017 Ram with the Alpine option. I don't want to replace the radio or the Amp I just want better quality 6x9 speakers. I've tried 2 different kind already and they didn't even sound better then the factory speakers. Just in case you were wondering... The first ones I tried were the powerbass OE-692T and then the jbl gx9628. All did not give me any more bass and very little extra highs. Can anyone help with this or is it a lost cause.
sorry I didn't read all the posts but humbly, in order to achieve top quality sound you have to spend the money, you know...get what you pay for, top quality costs much more, from just another avg joe!
Hardracer
2010 1500 laramie 4x4 crew cab
Is agree with everyone here about just changing out the stock stuff for a better sound.
I went all the infinity ref settups....to my ears volume level dropped a bit but the clarity was night and day to where I thought something was wrong with the system....as time went on I started noticing all the different sounds better....dont even notice the volume thing now and tunes I cant play loud as I did before just due to clearing up the diff.stuff.
Got an alpine amp under drivers seat for 2 old a** 10"mtx subs that thump just fine for my needs....really junk for the amp but do thump fine at my level....my case I made an enclosure for under the seat stuffed with poly also.think the pics are in 1 of my posts somewhere from way back.
Pics arent on my tablet but in my phone. I'll search tomm.and post them here if I find them.
Found it...
RLee276
Utah
I have a 2020 with alpine. I’ve spent almost a grand on speakers and the only ones that really made a bid difference was the the corner dash speakers.
I’ve tried infinity reference, alpine , audio frog , and jlb in front and back doors and the difference is negligible. And then you have to turn the volume higher to make up for it.
If if I could go back in time I wouldn’t replace a door speaker or sub unless it was blown.
I ended up getting a LOC and and amplified 12 inch power bass speaker from crutchfield and shined my back seat up 1.5 inches and the truck jams now.
Anyone who thinks changing a door speaker on the alpine system make a big difference is just having a placebo effect if you know what I mean.
The alpine amp adjust its self and its output based on the volume level to prevent people from blowing their speakers.
I think the alpine sounds good. And with a loc and amped speaker the truck rattles. But if you want more you will need to replace the entire system
One Mile Up
Colorado
6.4L Hemi
I’ve tried infinity reference, alpine , audio frog , and jlb in front and back doors and the difference is negligible...
This is basically what my installer said -- word for word... LOL ;)
I was thinking the other day that I might actually just end up KEEPING the factory Alpine amp to continue to power the center speaker(s?) and the two speakers that are mounted in the roof in the back of my cab (I have the upgraded 9 speaker setup)... I'd most definitely have to figure out some decent replacement speakers for those areas -- but that shouldn't be too complicated to figure out. I will 100% be upgrading the front door / dash (sticking to 6x9 components) and rear door (sticking with 6x9's) and powering those with my new 5-channel amp...
I have my appt scheduled for the 12th/13th... for my sub upgrade / sound deadening -- can't wait to see what it sounds like! Hopefully it doesn't SUCK! :cheers:
Hardracer
Arent there 12"shallow mount subs nowadays that can be squeezed In the back?
I know dam well I could glass up another box to fit a shallow mount(prolly could use what I have now)...I thought about it but really just don't care anymore to mess with it.....I still enjoy reading about what can and shouldn't be done though.
CanuckRam1313
Ontario Canada
Take a look at AudioMobile EVO or GTS subs.
They are specifically engineered for shallow/small enclosure sealed boxes.
Stuff the box with polyfill, too. To trick the sub into thinking it's in a bigger box thus producing better audio quality.
My 10" slams hard and clear in my sealed sub box under the rear passenger seat in the little well.
Atcer2018
Virginia
OP has the Alpine system which I believe is a 2ohm system. Using aftermarket 4ohm speakers will be harder to drive than 2 ohm. The 4 ohm speakers won’t be as loud as the 2 ohm at the same amp power output level. The Alpine also has a preset built in DSP so aftermarket speakers won’t get full frequency ranges. It’s a lot easier to upgrade the basic six speaker system.
One Mile Up
Colorado
6.4L Hemi
I yanked my factory enclosure out this past weekend to prepare my factory enclosure for the upgraded subwoofer going in this upcoming weekend and I was astonished with the bass (minus the factory sub) that the factory 9 speaker setup still had…
I thought I read somewhere that the sub was running at 8 ohms… not sure about that tho…
Jay_ramble
AZ
Is there a list anywhere that shows what impedance each alpine speaker is? I'm thinking about throwing in some new 6x9s myself
RAM286
