Richard Kim
- Jan 23, 2018
- 171
- 253
- Location
- Houston, Texas
- 2016
- 5.7 hemi
Atcer,OP has the Alpine system which I believe is a 2ohm system. Using aftermarket 4ohm speakers will be harder to drive than 2 ohm. The 4 ohm speakers won’t be as loud as the 2 ohm at the same amp power output level. The Alpine also has a preset built in DSP so aftermarket speakers won’t get full frequency ranges. It’s a lot easier to upgrade the basic six speaker system.
You are absolutely correct in regards to the 2 ohm system. If you put 4 ohm speakers, there will be a volume difference. Everything is controlled by the OEM Alpine system amplifier. The front door speakers are mid bass only. The rear door speakers are full spectrum. I replaced the rear with 2 ohm JBL dedicated 3 way and it did make a huge difference (getting full range). The OEM door speakers have the same 6X9's front and back without a dedicated tweeter (hence the muffled sound). Hope this helps.
