Odin510
I just bought a 2013 ram Hemi 5.7 60000 miles
I first notice a smell of coolant then check the coolant reservoir was empty. I found the coolant leaking from upper radiator hose connecting to the thermostat housing. The spring clamp was rusted and broke then trying to release the clamp. So I assumed the clamp was the issue. I figured if I’m going to replace the clamp and drain the coolant, might as well do a coolant flush, replace thermostat, upper radiator hose, dorman spring clamp 2” -2”. After all complete, I smell coolant and the same leak.
Leak is at the the connection between the upper hose and the neck of the thermostat housing.
Any ideas? Wrapped thermostat housing? Too big of clamp? 2 1/4 size
Thanks
Thanks
