Help me please. Mid install
WadXpress
HEMI
Am I missing the part that holds the spring on the bilstien? They are ground force 2" drop springs. I dont know what that is called. Perch? Is the stock one supposed to be reused? Or anyone know where I could get 2?
WilliamS
Tampa FL
you tap that with a hammer a few times and slide it off the same way as the spring and drop onto the bilstien. install the perch at the desired height and drop it on.
it goes on the same direction as the old shock, do not flip it over because you think it makes sense. if you can see the washer/perch you did it upside down
UnsatFC
Active duty NAVY
New Jersey
It’s the spring seat and the OEM one is taken off the factory struts and re used on the bilstein. I have heard they can be hard to take off but they DO come off.
W
WadXpress
HEMI
Thank you for the quick reply
W
WadXpress
HEMI
I think you saw them in the 4x4 thread but here you go. Measures 35" fender well to ground front and back
VB712
Maxi_built
Va Beach
Looks good. How low did you do in the rear?
W
WadXpress
HEMI
Just 4" belltech springs. Didnt cut the springs
VB712
Maxi_built
Va Beach
I want to lower the front of mine. Alignment come out good?
W
WadXpress
HEMI
I'm waiting to get into the good local alignment place. The clowns at les schwab want 105 bucks a hour to tinker with it and have no clue what they are doing
stevenmicheal
