Tbonesteak
I just had my 46re transmission rebuilt. I was told that the check valve or torque converter anti blow back had previously been drilled out. So now when I put it in drive or reverse it goes no where ! He told me to start it in neutral and let warm up then it will pull sometimes!! However I've had truck for 10 years and it's been shifting weather the check valve had been previously drilled or not!! I'm trying to figure this out?? If I go out right now and start truck and put it in drive it will roll backwards but if I put brake on and put in neutral then wait a few minutes and put in gear she'll catch!! Anyone have any ideas what I'm going through or what I need to fix this??? This wasn't ever a issue before it went out ?? This is on a 2001 dodge ram 1500 2 wheel drive!!!!
