Help needed
Caycray
Hey guys, I recently bought a 2014 ram 1500 big horn, and want to start doing some stuff to it. The first thing I want to do is get new headlights. The problem is I have the reflective style headlights and want projectors. If I buy new projector headlights are they just plug and play? Or do I have to do some other wiring? The second thing is, I need some good websites to look for ram parts and accessories, I've been having a hell of a time finding stuff. Thanks for the help!
7777xm
Covington, GA
The projectors will not be plug and play. You will need the harness adapter.
Are you going to be running halogen in the projectors or upgrading to HIDs? The output of the projectors is nearly identical to the halogens which isn't much to brag about LOL
Sent from my SM-N920T using Tapatalk
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Definitely get in touch with JJ at Retroshop. They have everything you need to make this possible for you. Not to mention, some absolutely amazing headlight options depending on what your budget allows.
Retro Shop Online Store
Adam
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Definitely get in touch with Retro Shop for your headlights. They make a plug-n-play harness to use the OEM projector headlights, and they can customize them any way you want as well.
They built these for my 2015...custom paint, custom FXR projectors, clear side reflectors, and 5000K HID's. They do very good work.
atc06jh
Middle Georgia
I got mine off eBay. I got the Spyder ones and they're plug-n-play. The only thing you have to "wire" is splicing the little LED and HALO lights into the running lights. Not that hard. Retro Shop has amazing choices, but you're going to spend well over $600 just for the headlights, over $750 if you want them painted. If I had the money to blow I'd order some from him for sure! But...I work for the government so I'm broke....
chad_chittenden
3.7L v6
maybe you can help me. I feel silly not knowing the answer to this. But how can I tell which headlights I have in my Ram? I have a 2015 Ram 1500 SLT 3.6 V6 I want to change the bulbs in my truck to something more white (not HID) but I don't know what type of lights I have so when I search for bulbs the question is always do you have projector lights. Any help would be great.
Thanks
