jmlee44
All, new to me 2007 Ram crew 4x4. I bough the truck knowing the front end is a bit loose and now I'm starting to get parts together to repair it.
My concern is an OEM part might not fit depending on what the prev owner did, the truck sits completely level and I'm guessing that isn't the factory ride height in the front - although with so many trucks leveled online it is hard to tell what is and isn't by looking at pictures.
Would anyone know what the tire to fender measurement is on a stock truck in the front?
If it is only leveled a couple inches, what is the normal process for this - parts-wise? The reason I ask, I need a driver side spindle because the tie rod wallowed out the hole from being loose (this is what you get when you buy trucks from HS kids). I want to make sure that I'm still looking for OE size spindle, and UCA/LCA or are those usually replaced?
Thanks in advance!!
Thanks in advance!!
