HELP!!! NO BLOWER FAN
Connorboy77
Mountain home AR.
I have a 83 ram, one day the blower fan stopped working so I hooked it to 12v and it fired up I checked the plug and no power, I checked the fuse no power. I took out the fusible link and still nothing the resister looks good. I just cant figure it out, is there anything I'm missing or any common problems. Thank you
crazzywolfie
under the truck
are you sure you replaced the right fusible link? it should be the orange one connected to the pink wire. if that doesn't solve your issue it is possible that you might have a bad ignition switch. also did you check the fuse with the key in the run position?
C
Connorboy77
Mountain home AR.
Yes it was the orange one, I'll have to take a look at the ignition switch but I'm pretty sure the man I bought it from just replaced it.
crazzywolfie
under the truck
there is more than 1 orange fusible link tho. there is a orange fusible link connected to a red wire. you want the one connected to the pink wire
crazzywolfie
under the truck
well if you have power at the fusible link and no power at the fuse pane it is possible you got a bad ignition switch. you can double check for power at the pink wire on the ignition switch connector in the cab.
1Popeye
