Clayton Bearden
I just bought a 2019 RAM 2500 Mega Cab with the OEM puck style gooseneck prep package. I want to use my existing B&W Companion 5th wheel hitch Model # RVB 3500 with it. Issue is the Companionl has a square shaft that drops into the hole that requires a locking pin. The OE hitch is a round hole with no locking pin. I found an adapter (Popup FLC-1 Companion Adapter) , but it also requires a pin. I love the compact hitch and don't want the bulky puck hitch. Where can I find the proper adapter? What is the proper adapter? How do I fix it so I use the OE gooseneck and the Companion? Thank you in advance. I appreciate the help.
