help on lowering the front
James_Reames
I need some suggestions should I just cut the front coils or order some drop coils and what shocks should I go with?
charonblk07
Calgary, Ab
F1-A forged 349ci
If it's a 2wd then you have plenty of options for lowering. You can cut the springs but that can mess with their spring rate and kill the ride. The spindles are always a good choice but they bump your wheels out 3/4" or there are the springs which are the easiest to install. Any of them work, just look at what you want to spend and if you plan to do it yourself.
I love the Belltech shocks, and their nitro 2s have served well in the past.
J
James_Reames
I was just thinking about cutting one coil off would stock shocks work or should I just replace them
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
A little info, the 5.7 and 4.7 are the same springs. Measure 6 inches of spring and it will lower about a inch. Spindles IMO is the best way to drop the front.
icywhite
Spindles i have springs and im going to switch as soon as i can get some extra cash im tired of eating up tires. it wont go stright up with the large rims i have so the inside of the tires ware
Statcher1
Kentucky
Spindles are your best bet. Save up alittle extra cash and get the Mcguahys deluxe kit
stevenmicheal
