Help PLEASE
Dubb
2010 Dodge Ram
Posted in Tech info area but I need help ASAP. Drivers window fell off track cuz it was frozen shut and I tried to open it(didn't think it was frozen). I have the panel off and I can access the rear clip via the rubber access panel and believe I can access the front one if I remove the speaker. So, how do I put the window back into the clips? Window has holes in it that clip into some plastic clips, like I said I can see the rear one. The motor is working so that is not an issue. HEEEEELLLLLPPPPPP!!!!!
Google replacing window regulator and watch the vids. Here's one for a durango, they probably have one for a Ram out there.
D
Dubb
2010 Dodge Ram
I did that but these clips are plastic one at the front of window and one at the rear. It appears the holes in the window fit into the clips just not sure how to open the clips so the window will fit back in to them
D
Dubb
2010 Dodge Ram
up top
