Help
Ternsdorff
Washington
Driving down highway and low oil pressure light came on. I pulled over turned off and checked oil. It smelled hot, but still full. I towed home, drained and refilled,checked codes and try to re start and starter will not engage. Any help, ideas?
2019 ram 2500 power wagon, 5th gen, with 26,000 miles
retired
montana
Should be under warranty.
Dredger
SE Ohio
I'm very sorry to hear that. Please let us know what occurred and the solution when you find out.
T
Ternsdorff
Washington
That's. The route it's going after they get back in the shop. Thank you
T
Ternsdorff
Washington
So it's at dealership and it sounds like new engine time. The starter had failed, which is odd it did it at the same time. They replaced starter and started it to hear severe engine knock. They are now sending it through the warranty process for possibly a new engine. If there is anything the ram cares team can do to help this process along, please let me know. I don't know how to get hold of them.
Thank you
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
On Warranties, the dealer makes suggestions, writes it up & takes pix & it goes to engineering.
Engineering may OK a repair or ask for more information
rule18
Admin
Administrator
NY
2017 Rebel
Thank you
I'll tag them here . @RamCares and also if you hover over their user name you can click on Start Conversation to begin a private message.
RamCares
n/a
n/a
Hi,
We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support via private messages.
Rob
Ram cares
T
Ternsdorff
Washington
So update. Dealer says it needs a new engine and new starter. Corporate is denying engine. They say the oil plug fell out and the engine drained, then I refilled it to make it look good. So I did drain and refill oil hopping somehow that would reset computer to allow starter to engage. I even have old motor oil still.. I know Longshot but these computers controll everything.
I gave receipts for oild changes, fumoto oil drain valve and woolwax,. Provided maintenance history (shory since only at just under 25,000 miles) oil changes every 4000 to 4500. Along with diff fluids air cleaners etc. Dealership is in Everett, wa.
The reason they say it was drainedof oil and plug fell out is 1. There is an aftermarket fumoto drain plug in pan as with all vehicles. And 2 the underside was coated with woolwax for winter and they claim that is engine oil. It's straw colored woolwax, looks and feels nothing like motor oil.
Be ware anyone who wishes to rustproof under there car or use fumoto oil valve. Dealership says they know rust proofing and it's hard not oil like. I even provided receipts, pics of 5gal bucket and picks of what woolwax looks like along with their web sight.
Ughh. I may have to get an attorney or eat what they say will be over 10,000 for a new engine on 2 year old truck. I can't let it sit with no engine, and keep making payments. After this I'm tempted to get engine in and trade in on a Ford. Between this engine failure and the chronic lifter / Cam failures with lack of corporate standing behind their product I'm just not sure it's worth it. I waited to get a power wagon for years now itslooking like a huge mistake. I only put 8,000 miles on it. Bought 1 yr old with 17,000 miles from dealer
