Help
Ddot13
Can anyone help me . I have a 02 ram with blown 4.7 an a 03 with good 4.7 . Am I able to swap the motors ? I called dodge they said no because there different block numbers . Can't I just use the 03 block an put the 02 parts on it ??
RonJon '06
Southern Minnesota
After some searching it looks like the crankshaft sensor tone rings are different, 16-tooth on the '02 and 32 tooth on the '03. The number of PCM connector pins should be different as well, 3 pin on the '02 and 4 pin on the '03. I found all this info on another forum.
D
Ddot13
See that's what I thought but my 03 has only three connectors on the computer
RonJon '06
Southern Minnesota
Then I would think it should work. You could take off the oil pans and compare tone rings to be certain. As far as I know the only other difference from '02 to '03 should be the TCM which you can swap. Maybe someone else who knows more about the 4.7L will chime in.
D
Ddot13
Thanks man I appreciate it . I just want to be 100 percent before tearing into both of them .
a17ram
