Hemi 05 please help
mccleney80
I hook the computer up it says (P0340) camshaft position sensor not it so I tried crankshAft position sensor it's not it I checked wiring it looks good I cleaned throttle body...last thing I tried was A mass position sensor but nothing im hoping it's not the (PCM power control module) it starts but quits after about 8 minutes...does anybody know what this is please help thank you
Sent from my MotoG3 using Tapatalk
jotin
your mom
That's the only code you're getting in the PCM?
M
mccleney80
Ya is P0340 I've tried everything that has 2 do with this situation the engine still dies on me
OutLore
Raleigh, NC
Once it has quit after 8 minutes, does it restart and run for another 8 minutes, or do you have to wait for it to cool before it will start again?
M
mccleney80
I have 2 wait Awhile before I can start it again
M
mccleney80
After 8 minutes I have 2 wait awhile do u have any idea what is going on with this hemi?
M
mccleney80
Ya that's the only code dude I need sum help on ideas if u have any??
jotin
your mom
Wel you've done a cam and crank sensor. So you've ruled those out. When the truck dies do you lose power to everything? Or is it just that the engine dies? And when you restart it,does it start right back up?
M
mccleney80
When it dies after 8 to 10 minutes it won't start back up until I wait awhile since all this has happened I haven't drove it anywhere..when all this started it started first spitting and sputtering until finally now it just won't run for longer theN 8 to 10 minutes
sbarron
Wasilla, Alaska
Does it have an air charge temperature sensor?
OutLore
Raleigh, NC
If it runs for 8 mins, then cuts out and you have to wait before it will start, then it will run for a bit and cut out - my guess is that it's heat related.
So could be a sensor going bad, but I would think that would at least throw a code, could be some kind of short that only happens when things are hot?
Do you know anyone with a scanner that can monitor the sensors then you can see what's happening with them as it cuts out?
