Slowbro
- Jul 16, 2013
- 41
- 11
- 2008
- Hemi 5.7
So first off, this is my first legitimate post on Ram Forum, I've been lurking a while but only just now have felt the need to post. Anyway, I have an 08 5.7 hemi 4x4 and as of today it's been acting really odd when I start it. Truck cranks fine and then the revs build to a little above what idle should be (so floating around and above 1k) and then fluctuate up and down. While this is happening the lights in the truck flicker gently. This is a new issue to the point that I drove the truck earlier in the day with no issue and came back to this new headache after leaving it sitting for a few hours. The only thing that has changed is the weather. It got cold. Like, 40 degrees F this morning down to around 10 degrees F with windchill tonight. I've had the truck since July so I haven't seen it experience truly cold weather until now. It's sitting at around 33k miles and is entirely stock. I've tried searching and have come up with everything from bad plugs, bad crankshaft position sensor to bad voltage regulators. I even found one guy who described the EXACT problems I'm having down to the cold weather, but the thread didn't yield any good solutions so I'm curious to see if I can get some more info on this!
