Hey @Dutra ,Sept 2022 I went to the dealership and was told part is on back order. I just got back today and the part is pushed back until August 2023. They are waiting for my warranty to expire
Good video Clint. I've fixed similiar brush set-ups a few times over the years,and also use a small fine toothed file to clesn up the inside of the brush housing,especially the end where the brush sticks out. I'd hazard a guess it's probably a fairly commonly used brush that should be replacable if they are wore down,(just be a matter of finding them),but usually by the time the brushes are wore out,the commutator is also wore out.I'm old enough i still remember the days of turning starter armature commutators and sticking new brushes in them,lolHere is a video i have put out to possible help with this issue. The Abs motor brushes are frozen in its housing. this was on a 2017 ram 5500 with 58K miles. had already had the module replaced under warranty then it happened again. check it out!
RAM ABS Code C0020-01 FIX!!! on 2017 5500
Here is a video i made to help all you Ram owners with the dreaded abs code c0022-01. This was on a 2017 ram 5500 cummings. The complaint will be abs light a...www.youtube.com
