GaRamGuy
- Apr 20, 2019
- 21
- 6
- Location
- Warner Robins, Ga
- 2005
- Hemi 5.7
Been chasing this problem for awhile. Very first start of the day is great. Wait an hour and it hesitates. Fuel pump pressure is good. Checked for leaking injectors by pulling and checked for leaks while priming. I installed new:
battery
throttle body
crank sensor
Starter
IAT sensor
Egr valve
Cleaned all ground connections. Inspected all fuses. Truck has 42K mikes owned since new. No codes thrown ever. Alternator passes charging test. Charges at 14.2 volts with AC and headlights turned on. Any help would be appreciated.
battery
throttle body
crank sensor
Starter
IAT sensor
Egr valve
