HID cost
SwollenMonkey16
I've got the regular crap quad headlights and looking to upgrade to projectors. I know the cost for the headlight assembly is between $400-600. Once I purchase those what should a good HID kit cost and to get installed?
JoshR104
Check out morimoto brand they make quality stuff and Nick from gotexhaust can hook you up with a good discount.
JoshR104
Thank you Sir
No problem and if you want to really up the output and feeling up to a task you can open them up and retrofit FXR 3.0 into it. They make an adapter plate and here is the light output from mine that I did. Fence across the road is about 100 feet away just low beams no fogs on. Or wait for the morimoto xb lights coming out.
SwollenMonkey16
SwollenMonkey16
Man those things are sweet. Yea I really want to increase my light output bc I do a lot of night driving and sometimes with these OEM halogens I can't even tell if they're on.
JoshR104
Retrofit would be my advice... I just finished these pair. This is my second set I have done now. If you take your time and dont rush it they arent that bad.
JoshR104
Although those XB are dual projector for low and high so you have quad lowbeam / highbeams. Pretty sure they are using there m-led projectors as well that are pretty close to mini ds2 output.
cuminslvr
Pennsylvania
3.0 Diesel
SwollenMonkey16
SwollenMonkey16
Another concern is seeing if its something easy enough for myself to install. I'm very sceptical of having a shop install them bc they don't always know exactly what they are doing. I know a lot of ppl who have had bad experiences with shops installing bad kits. So I can buy all the good quality products and if I feel I can't install then I can have a pro do it and know I bought the right stuff
Underground Lighting
Supporting Vendor
UNdergroundlighting.com
Plug and play error and flicker free. 15% off for forum members. Use code Ram15
TheM4rxxx
