octane03
I'm looking to put a HID conversion in my 2010 ram.
What's the best way?
When I use remote start the headlights come on before cranking and stay on during crank, then shut off for a few seconds then back on and stay on. I'm not sure how the lights react when started with the key.
I've installed HID in about 7 vehicles mostly GM.
And use a time delay relay so they don't come on until they have power for a set amount of time. (Until after the vehicle starts) so they dont turn on and off and flicker. (Which is bad for the ballasts)
But what should be done with my ram? Also I have the single bulb hi/lo beam and will be getting the correct bulbs with the hi and low beam tilt feature. How does this work with the DRL at half power high beam? What do I do about that?
Also will I need a error code eliminator?
I always buy from DDM tuning for HID's.
Thanks for advice in Advance!!!
