HID placement
Mike Townsend
Sorry about another headlight post. I am trying to upgrade my projectors on my 2014 1500 r/t and I ran into a couple things. I got JDM fog and high beam LED's. The fog lights went in in about 30 seconds. I tried to put the HB in and the fan and heat sink are too big. I am going to have to send those back. Any suggestions on LED high beams that fit into the projector housings?
I also got DDM HID's and am kind of stuck. I am trying to figure out the best way to install these. I can pack it all into the headlight but not sure if that is a good idea. I figure they will get hot and I am not sure hot to mount them in there so they don't rattle. The other way is to drill a hole in the dust cap. That makes me nervous because I don't want moisture to get in.
Any pictures would be appreciated.
Dmopar74
I've had my ddm hids crammed in my headlights for two years, not mounted, and not once have ever had a problem
NoveskeFan
Historic Triangle area in VA
2017 Crew Cab Short Bed Copperhead Sport 4x4
I mounted my DDM ballasts on top of the black support as seen above. I ran the wiring behind the support, not in front as seen in the pic. My tetris skills must suck because I couldn't see how to fit everything in the housing.
Mike Townsend
Mike Townsend
Thank you for the picture. Do you have one of the dust cover I'm assuming you had to cut a hole in?
NoveskeFan
I don’t. I just drilled the hole near where the low beam sits and the grommet has done a good job so far with moisture control. Some people add silicone to the area around the grommet for extra protection.
jasonw
South Dakota
3.0L Hurricane HO
I did not use DDM, but I packed mine inside the housing. Not mounted, they're a tight enough fit they don't rattle. Been over a year, somewhere in the neighborhood of two, no problems here.
Mike Townsend
Mike Townsend
OK, I will try and put them into the light housing. Different question. I got the JDMaster LED for the high beam but with the heat sink and fan so large I couldn't get them in. Is there another brand that someone can reccomend
JoshR104
I think headlight revolution had a pair they said would fit in the high beams but they were like $220 or something like that. I plan on putting in LED pods in mine as a retrofit.
