HID problems.
djbeck88
Alright I have an HID issue that I can't figure out. I have a buddy with a 05 1500 hemi. Has HIDs. We though that the passenger HID went out so we changed them out. The new ones worked for about two week and then the passenger one took a dump again. Any ideas?
olbaid_83
Fort Worth, Texas
check the voltage to the bulb......im not real good with hids but i do know electronics and high voltage can cause a burn out quickly.
05singlecabHEMI
Lilburn,GA
Check all the grounds, and maybe take a wire brush to them just to be safe.
Test the voltage at the light as said above.
Check all the wire connections to make sure there are no loose wires.
Check the resistance on the resistors.
quietpeen
2021 TRX
Hellcat
I moved this to the exterior section since is about headlights
Vendor
Florissant, MO
2x 5.7L & 6.2L
quietpeen
2021 TRX
Hellcat
That's it screw This and the phone lol
Flashback
Grounds grounds grounds. Make sure that every ground is good.
mikep345
