HIDs flicker like hazard lights
BlackBee
Upstate NY
I tried wiring my Heads and I go to turn on the headlights and they just flash as the hazard lights would. What should I check?
And you can hear a clicking noise
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
your harness is not the right one for the job.
You need one that has resistors built into it. DDM ...... bites.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
get them to make it right..........or get a harness that works for your truck. ;)
Refresh my memory.......what did you get again? What was the cost?
BlackBee
BlackBee
Upstate NY
It was 160. Harness ballasts lights. No resistors built in.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
BlackBee
BlackBee
Upstate NY
So I just received these 2 resistors. But why two? I only use the stock plug on one side right?
And where exactly do they plug into?
Vendor
Florissant, MO
2x 5.7L & 6.2L
most of the time on the pass side they are plugged in to keep you from getting a lamp out.
