hitch skid.
Quyonmob
Canada
This is top shelf thinking. Simple, protects the hitch, helps scrub off departure rocks.
now, is it strong enough near the top to incorporate a shackle mount that wouldn’t interfere with departure angle? That would be the perfect combo.
retired
retired
montana
It will also help push the nose of texting Honda Civic drivers into the ground. ;-)
Looks like a nice project. Does it interfere with Parksense?
hasn't yet. I figured if I put it tight to the bumper it should be fine.
retired
retired
montana
Good question. the gussets are 3/8" thick and the plate is 1/4" and the tube is heavy duty 2.5" 1/4" wall tubing.
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Found this on a quick Google search. I may have to get one of these. After I install my AEV rear bumper, I’ll have two recovery points mounted to the frame, a nice hitch skid might not be a bad idea.
IRSmart
Westminster, MD
2018 Power Wagon
6.4L Hemi
I would like to place an order!
Right? I’m seriously considering one of these now. The fact that it goes out just farther than the bumper is brilliant, that way the ledge follows the slider down, and the rear bumper “should” never make contact with the ledge at all.
crazy jerry
WY
sweet. what kind of metal bender do you have ? i would of had to make a welded seam at the bend because ive got no way to bend it and likely not enough room in the garage for more machines:(
retired
retired
montana
No bender just welded.
crazy jerry
WY
ok it looked like you may have used a bender but couldnt tell
crazy jerry
WY
**** i must of missed the first photos. i see where you welded it now. haha
