ericbsc
- Nov 22, 2023
- 12
- 13
- Location
- South Carolina
- 2023 1500 limited
- 5.7 etourque
The motor has several different internals than the lower SST. Motor tuned to run 91 +++Just traded for a 2025 longhorn limited. I knew the fuel said 91 octane. Why ? What would it hurt to run mid grade?
You might want to check into your warrenty,as it might disappear if they can prove you didn't run the required fuel.
I agree but guys should not trivialze the extra cost of having to run premium. If that is his daily driver, that is 800 to a 1000 bucks a year, 4-5000 bucks over 5 years. Guy should factor in running costs when choosing a daily driver. If the extra grand a year is no big deal, good. If it is. Might be should choose a different vehicle or engine option.Run premium, the truck cost over 70,000+ my guess is a buyer can afford a few extra dollars on gas. IMHO, it isn't worth the risk of one of the numerous sensor crapping out because an owner chooses not to follow the requirement. As was stated, you're giving a dealer a reason to make any issue your problem. The total savings if you filled up 33 gallons would be between 9-16 dollars, seriously doesn't seem worth it.
They have zero reason the REQUIRE 91+ other than damage.
Regular to premium here is about 45 cents a gallon more for the extra octane.
I wish premium around me was as close to regular as you guys. Premium, 91 octane, is always 80 cents to a buck more per gallon then regular 87. I still use premium in my truck, just because it doesn't have ethanol. It's not my daily so it sits a lot.The total savings if you filled up 33 gallons would be between 9-16 dollars, seriously doesn't seem worth it.
I am willing to bet it is in the timing charts and the detonation will happen too fast for the sensors in the HO, can you go 150K miles problem free? maybe
But I will not even attempt it.
I think you mean 45 cents more per litre not a gallon,lol.You bought an HO for more power. Part of how more power is made is running higher octane fuel. If you want to run it on cheaper fuel that is your choice but it isn't optimal. I have high performance V8s in a couple of cars. The high compression, naturally aspirated motors want premium gas. It is what I feed them as I knew about the requirement when I bought them. Regular to premium here is about 45 cents a gallon more for the extra octane.
Costco. 135 for reg, 155 for premium. 20 cents time 3.8 is actually 76 a U.S. gallon but up until recently premium was only 15 cents more a litre so 57 cents a gallon. I just did the math, I was ballparking it earlier.I think you mean 45 cents more per litre not a gallon,lol.
If you're getting 91 for only $0.45 more a gallon then 87,i want to know where,lol
I've never bought fuel at costco,as it's a fair ways out of my way,and i don't have a membership card,but that's good to knowCostco. 135 for reg, 155 for premium. 20 cents time 3.8 is actually 76 a U.S. gallon but up until recently premium was only 15 cents more a litre so 57 cents a gallon. I just did the math, I was ballparking it earlier.
Would love a link to that post/comment/videoI don't know it'll go 150k miles on unicorn tears and 99 octane super premium extra v irgin organic gasoline, but the chief engineer for the Ram 1500 (Doug Killian) has publicly stated 87 octane won't damage the motor.
I'd be more concerned about heat downstream and emissions components than the motor not pulling timing fast enough, but I'm not buying one so it's pretty hypothetical to me. I'll stick with my dumb ol' naturally aspirated 6.4L.
