Horn Blows
mikeonmain
2013 2500 Tradesman Maximum Steel
Does your horn have a .5 sec delay.... I slap my horn to say hello to my neighbor and it sounds off half a block later...and not with a short blast but this long "get out the way" blast... I refuse to use it
audio1der
Airdrie, Alberta
First off I think we have to address your main concern here; speeding in a residential zone.
City blocks vary considerably in size, but a good median size if 300' long. If you covered half a block in half a second (the delay of your horn), you were travelling at 447mph in your own neighborhood. First, congratulations. Second, I hope you take the truck to the Bonneville salt flats and represent us well; that is an impressive speed. Third, I'm pulling your leg and sorry to hear your horn is slower than a GMC :ehcapt:
mikeonmain
mikeonmain
Hahaha I thought it was just my truck... I had no problem with my 06
VolsRam
Franklin, TN
HEMI 5.7
HAHAHAHAHAHAHAHAHAHAHA!!!!! Love this!!!
RCFiddyOne
Same here. I want to do a quick tap most times and it turns out as a long blast. I thought it was just me.
DatacomGuy
Tampa, FL
Not to hijack..but..
I really would like to install an air compressor and some sort of semi truck horn.. Any ideas? I don't want train sound. I want 18 wheeler sound!
audio1der
Airdrie, Alberta
I'd say your budget is about the only restriction. With a good size tank and compressor, along with large enough bells, you'll get that deep semi truck sound. It's not cheap!(or we'd all do it LOL)
Bombdigitty
same.. Its hard to get a quick beep beep off. Quicker to roll down the window and wave.
Koko
Dudley, MA
My wife thought I was nuts when I told her this. I feel the same way. The only thing I miss it for is pulling in the garagr and the kids open the door to the house. Id usually blast off a series of quick horn beeps for them. Not anymore.
DatacomGuy
Tampa, FL
What type of horn/bell should i look for? What length/size?
audio1der
Airdrie, Alberta
I'm sure there are many here who know more than I do; I've just done some shopping but the wife says 'No, until it's just a toy"...
I would buy it somehwere they sell real stuff; at least a step up from Pep Boys.
Air Horns: Big Rig Chrome Shop
Truck Horns, Air Horns & Train Horns At StylinTrucks.Com
Air Horns of Texas, Train Horns, Train Air Horns
They all have good stuff starting from a few hundred bucks for bells, compressor, tank etc to sky's the limit. Check out Unbroken's truck, with a real set of 5 train bells under the truck. Apparently it's BONKERS loud :happy107:
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
I have this delay also. It even happens when I double tap the remote start. This didn't happen with my 2012. Maybe it's a 13 thing.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
My only conclusion is that the horn is somehow computer controlled. If that is the case there is a solution. Find the trigger wire, tap in, wire to a relay and connect that to the horn. Bypass the delay all together.
If I have time this weekend I'll figure it out and write up a How To.
DatacomGuy
Tampa, FL
Perfect. I'll do some research. Thank you sir!
toofart
QC Canada
Hemi 8 spd
Yep same delay here. I don't feel like I'm the one controlling the horn, sucks big time.
WhiteExpress
Midland, TX
I put Green LEDs in my High Beams (Bixenon projectors take care of useful light) so I just use my 'flash to pass' to wave. I've noticed my horn takes longer than it should as well.
audio1der
Airdrie, Alberta
I just used our horn for the first time last night ("Uh, it's been green for a while now, bud") and gave him 3 blasts instead of a short one or two LOL
There is def. a pause.
stevenmicheal
