How do I clean windshield washer res sensor
Toddbigboytruck
Ontario
My windshield washer fluid empty light is on but it is full I have read on line that if you use rainx you could have this issue. Any one know how to clean the sensor with out removing it from the tank. I can’t find and well it is cold and snow so laying on the ground right now isn’t the best
Thank you
huntergreen
I would just add the blue fluid if your not having an issue.
DILLIGAF
Canada
Change brand. Wont matter if you clean it. Some types just dont jive with our senor.
Loudram
Just a sinner saved by grace
South Jersey
Ok how did you located the sensor
I honestly don't remember. I know it's on the bottom so I just spun the brush around and check to see if the light went out. First or second try and it was out.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Best way is to use a suction device, like a turkey baster with a longer hose, the tank holds close to a gallon of fluid
When you get the level down close to the bottom
Then take a brush & work it around the sensor.
The way to tell if your sensor is bad is, after brushing the sensor clean, see if it sprays on the window. or at least dribbles, to see if the pump is ok
If it squirts, empty the windshield washer reservoir
This is the thing that everyone should know:
If the washer fluid beads on the windshield, it is not good for a Ram trucks windshield washer pump
Toddbigboytruck
Toddbigboytruck
Ontario
Yes I should have not not used the rainex
Dean2
Near Edmonton
Put some blue washer fluid in it and a couple of good squirts of Dawn, Sunlight or whatever liquid dish soap. It will clean the sensor, lines and inside of the tank. Takes bugs off way better too.
SwampRam
Did you ever figure out how to get the sensor off? Mine seems stuck. BTW mine is a 2002.
