How do you get the engine CLEAN?
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
REDinAZ
Arizona, USA
2017 Crew
5.7 2wd 3.92
I use Simple green, rinse it off, use my compressor to blow the excess water off, wipe down then use 303 Aerospace Protectant. Does not have a "glossy" shine but it looks really clean. It's about 1000% better than Armor All .
303 Aerospace Protectant, 303 aerospace, 303 protectant, aerospace protectant, 303 products, 303
Jay
PY, you probably already have, but, if you haven't, you MUST grab a bottle of the 303 "SPEED DETAILER" for the occasional exterior wipe down/touch up!
RED
Dean2
Near Edmonton
I have washed my engine bays at the wand wash for 50 years. Spray on the degreaser, bug remover that comes out at pretty low pressure and let it sit while I wash the rest of the vehicle. Use the rinse mode to remove the degreaser. I don't cover anything but I also don't spray real close, just use the water at a distance to rinse. Then final is the spot free rinse. No water spots, clean engine. I then wipe hoses with silicone lube, and use that to lube hinges and hood latch.
Engine bay of our 1992 Forerunner - hasn't been cleaned in a couple of months.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Mist with Purple Power. DO NOT let it dry, keep spraying until everything is wet. Soak for 3 minutes approximately. Rinse with garden hose. Blow dry and start vehicle until dry. Then I shut it off to cool, and must the entire engine bay with either silicone spray or in a pinch Tire Shine. Once a year keeps it like new and usually only requires a wipe with a towel to get back clean.
REDinAZ
Arizona, USA
2017 Crew
5.7 2wd 3.92
FWIW the only aerosol foam degreaser that that I've settled on for engine bay maintenance is the Gunk "ORIGINAL" Engine Degreaser (and VERY specifically that aerosol only!!!!). Too often engine degreaser products are NASTY stuff, when coming into contact with paint or some plastics they WILL degrade them. That Gunk product will not. And yet does an outstanding job of cleaning the area you spray it on.
Just use your head, don't go spraying it all over (top of the engine) everything under the hood. I prefer the areas most grungy, usually on the sides of the engine and the bottom. I'll go in there with it on a semi annual basis. Simply spray the product where you want, let it soak, gently hose it off, then maybe take the truck for a few easy laps around the block to dry it all out. FYI, you WILL leave a nasty mess under the vehicle you just sprayed and rinsed this stuff off of. Personally I'd never do all this is right in my own driveway, just a recommendation.
REDinAZ
Arizona, USA
2017 Crew
5.7 2wd 3.92
18CD, +1 on the Purple Power.
Another you might want to try, and it's a gallon concentrate, so you put it in a separate spray bottle with distilled water mixed to your own preferred ratio "strength"....
Sherman Bird
Houston, Texas
ive all ways used a pressuere washer and kept the truck running cause you will know if your spraying water in the wrong place cause the truck will act up
did the whole cover stuff up thing once and had to wait for the truck to dry out for the day befor it would start so i allways keep it running now
There is actually a pictorial embossment on GM vehicles depicting a pressure washer wand with spray emanating forth. This is encircled with a slash going through the pictorial. Universal language for "Don't do this!"
I've seen many examples of high pressure water getting into places it doesn't belong in my 47 year professional career as a technician.
I use Purple Power. The grease and dirt literally melt off and leave clen behind. A low pressure wash is then all that is necessary! :)
2020PW
East coast
Cleaners can be corrosive and accelerate the corrosion process. Simple green is one of them, unless you’re using the aircraft version of simple green.
Travelin Ram
+1 on that. I keep a gallon of the aircraft cleaner on hand for cleaning radiators.
Sherman Bird
Houston, Texas
Using pressure washers is all about having a little (un)common sense. A pressure washer at 6” will do damage.
At 36” it’s just aerated fog which makes a very effective rinse.
"Gee! My gun was on safety!" "I can't figure out how it went off!".
Treburkulosis
Your High End Detailer
Haslet, TX
F bomb wash it with car pro pink soap and pressure wash it.
