Sean McGillicuddy
Ok
Changing the oil in a 2017 Hemi was messy .. did they change this with the 2019?
A Fumoto Oil Drain Valve will make that a non issue! Been using them on all my vehicles for almost 20 years.What model?
I have a limited and it is worse! The filter is still a PITA and now right behind the oil plug is a crossbar!
Sadly no, it's not any better.Ok
thisOil drain no problem. Filter...a freaking mess.
No one likes a braggerI have a 2020 with 6.4 hemi and it is a breeze. Did my first oil change at 1111 miles and I was expecting the filter to be a pain based on what I read but if it were any easier it would change itself. no drips and no mess. RAM put a nice plastic funnel below the filter.
This, unless you have a show truck some oil down there will just protect that area from rust. Hit the entire under carriage with fluid film, it will all match, and smell good yummy.2020 Ram 1500 Quad
ha! big *** mess! I can say this, my front axle housing will never corrode, its covered with oil at every change.
