So, quick question... I love how many of the lights on my 2016 Big Horn are LEDs, but the interior overhead lights, rear cab truck bed light, as well as the license plate lights, etc. are not. Is it a major deal to change them all out? What I mean is, do I have to have an OBD scanner just to switch all of those out? Is it worth it? Thanks.
I have updated the low beam headlights only with the Putco 289005PZ low beam LED headlamp kit. Not as cheap as some, but work very well, and they do not have any cooling fan. They have been in service for a year. They are very bright at 6500K. Shop around, as you will find that the prices vary somewhat. I believe that I purchased them at Headlight Revolution. Check out their YouTube video. These are plug and play. Installation instructions are very clear; just watch for the two (?) extra bolts with 10 MM heads (?) that are not obvious and not in the video when removing the grille.So, quick question... I love how many of the lights on my 2016 Big Horn are LEDs, but the interior overhead lights, rear cab truck bed light, as well as the license plate lights, etc. are not. Is it a major deal to change them all out? What I mean is, do I have to have an OBD scanner just to switch all of those out? Is it worth it? Thanks.
Easy swap. No resistors needed on my '17 2500 CCLB. I used red LEDs in the cab because red doesn't ruin your night vision. Lots of Police cars have switched over to red. It also makes my Ram different than the other 147 Rams I saw today.[emoji51]
Also did the others you mentioned. They're all just brighter now. Very happy I swapped them all to LEDs.
The red light district!!!
I swapped my frt. blinkers with bright amber LEDs but, I still have that same problem with not being able to see to the sides. Do you have a link for those that you used?. Would sure appreciate it.I did all of mine on my tradesman. I did need to use resistors for the tail and blinkers. The best thing about this is they make leds for the front blinkers that are white when they are set to running lights and then blink Amber when the blinker is on. I can actually see whats to the left and right of the front of the truck. I have not use them plowing yet but this should be a game changer to be able to see to the side of the plow. The white light is so bright you can drive without the head lights.
I have changed headlight and fog lights to LED. I have the interior bulbs but I haven't installed them yet.
What type of bulbs are these ? Was it hard to change them ?Easy swap. No resistors needed on my '17 2500 CCLB. I used red LEDs in the cab because red doesn't ruin your night vision. Lots of Police cars have switched over to red. It also makes my Ram different than the other 147 Rams I saw today.[emoji51]
I'm thinking of getting the same. How are they holding up?I switched my interior and license plate bulbs with leds. Yitamotor sells a complete kit for around $10. No codes, no errors.
https://www.yitamotor.com/products/...ackage-for-2009-2018-dodge-ram-1500-2500-3500
Mine are ordered and will be here SaturdayI haven't had any problems with them, except for one of the plate lights fit a little loose and flickered for a while. Seems to have fixed itself though. I don't believe it was a problem caused by the bulb, more the socket. Definitely brighten up the cab though.
