- May 3, 2018
- 2,068
- 2,909
- Location
- North Prince George, VA
- 2017
- 5.7
I went through 4 big containers…I might have overkilled it a bit, but I can guarantee its flushed good!
Don't use a turkey baster, it's too big, use your pump! Great pump by the way, have the same one. Get 2qty quarts of fluid. Drain and refill the master several times, pumping many times between changes. Once the master is clean then start on the calipers.Thank for the responses! Something else I forgot to ask. I see you need to remove old brake fluid from the master cylinder with a turkey baster before you get started, but none of the how to vids I've seen say how much. Would it be to the low fill line or as much as you can get out?
