How To: 13-14 premium cluster upgrade
swoyekr
SE PA
So I installed a 13 cluster, and now I have a new problem. The voltage, Fuel Filter, and TPMS are all blank. THe TPMS I'm not completely worried about because it worked initially but also didn't work on the old cluster, I believe the wheel units are the culprit there. However, the fuel filter being blank and voltage is concerning.
Vin was learned to the cluster, mileage and hours corrected.
To be clear, my truck is a 2500 and I was installing a 1500 cluster without the DEF gauge. I was under the impression that this shouldn't be an issue since the cluster's inner workings are the same. Am I off base here?
278877801_10110476302901883_1953765854330974055_n.jpg278590165_10110476302951783_7467680171429410548_n.jpg278447882_10110476302926833_6867165709006658983_n.jpg
SitKneelBend
St. Louis
3.6 Pentastar
View attachment 491625View attachment 491626View attachment 491627
I'm not sure about diesel to Gas compatibility but I've seen the compass heading blank similarly due to incompatibility when a particular radio was installed (for some reason). All this to say it may not be caused by what you'd expect.
spacex
NH
Just picked one of these up for $335 with almost identical miles to my truck. Looking forward to installing!
spacex
NH
…can you test before putting into the truck? This is box I received…. Gauges appear to be in good shape but I don’t want to tear apart the dash if it’s already *****. EA1A276D-6A70-4EDC-9709-85B49EF43749.jpeg
SitKneelBend
St. Louis
3.6 Pentastar
spacex
NH
Got it. Will test it out…
swoyekr
SE PA
I've recently started grabbing these when I can to resell on ebay. If someone looking for something specific let me know I'll see what I can find for you.
