No, sorry. I don't have any extra parts left. I did not add the fault sense wire.^Would you have enough parts to make another set? And did you add the wire for the "fault sense?"
4.1 LED TAIL SIDE WIRING
If you sourced the LED pigtail from a junkyard, you will need to move one pin, and remove and discard another, as they are not all in the correct location for the 2013+ LED Tail Lights. Below is a picture of the contact that must be moved and removed and discarded.
I believe @Shaggy or @MADDOG can get t?you some Temp access to fix your original posts (not sure what the time limit is currently on edits . 6mos?)I can't edit my original posting from 7 years ago! (That is an engineers' cheerful attempt at sarcasm! )
Here's the original pic for that step:
I had to set mine in alfaobd to led. I've set everything to led and so far zero issues. I also made my own adapter harness, not sure that makes a difference or not though.I just installed the 4TH GEN RAM TAIL LIGHT ADAPTER (V2.0) purchased from Retroshop with a set of led tail lights. I'm currently getting a parking light out and reverse light out. Everything is functioning correctly after install. To get these messages to go away do I need to change anything with AlphaOBD? I have not changed any settings yet.
Thanks in advance.
You shouldn't need to change anything with those adapters from Jeremy. (I had the v1 w/ large resistors on my 13 ram 1500).I just installed the 4TH GEN RAM TAIL LIGHT ADAPTER (V2.0) purchased from Retroshop with a set of led tail lights. I'm currently getting a parking light out and reverse light out. Everything is functioning correctly after install. To get these messages to go away do I need to change anything with AlphaOBD? I have not changed any settings yet.
Thanks in advance.
